I have removed the textured wallpaper from the wall and the concrete is now exposed. There was a significant amount of glue, and I have used warm water with sugar soap and a scraper to remove as much of it as possible (the process was repeated 3-4 times and little glue was removed on the last pass, but the wall still feels very slightly sticky when wet).
Small holes have been patched with setting compound and then sanded. The wall is now fairly smooth, with some irregularities.
I am looking for a smooth (but not necessarily perfect) wall and long-lasting paint job so the glue is a concern. I am thinking about proceeding as follows:
  • Apply a layer of sealer to the wall (Zinsser Gardz High Performance Sealer, a water-based product. It looks like oil-based sealers were popular in the past but because of their smell and thanks to technical progress water-based sealers are now a good option.)
  • Skim coat the wall with some gypsum-based joint and filler compound, then sand (repeating the process twice).
Does it make sense to process in this order or should skimming happen first? Would this method yield good results?
I'm aware skimming can be tricky but I'm happy to learn how to do it. I have considered putting wallpaper on the wall but would prefer not to if there are decent alternatives.
  • Have you considered using drywall mud with some textured rollers?
    – JACK
    Aug 15, 2020 at 0:20
  • It's a concrete wall, you're not going to do much to damage it, consider giving that glue a good mechanical scraping to get it off. If you do happen to make a couple of minor gouges, you can skim those to smooth it out.
    Aug 15, 2020 at 18:02
  • @JACK in the skimming process I am thinking about using a medium-pile nap roller to apply the mud, and then use an oversized squeegee to smoothen it.
    – Jelefra
    Aug 16, 2020 at 10:56
  • @FreeMan I bought a 6" long-handled scraper to get the glue off after lightly spraying the wall with warm soapy water. I've been amazed at the quantity of glue that was scraped off! The concrete was quite smooth so I didn't damage it in the process.
    – Jelefra
    Aug 16, 2020 at 10:59
  • I'd suggest scraping it dry - the glue is more likely to chip off if it's dry, while if it's wet, it's softer and may spread a bit. At least, that's my experience with "regular" glues, I've not yet had the pleasure of attempting to remove wallpaper paste (though I fear that opportunity is coming my way).
    Aug 16, 2020 at 12:24
I think you have the right idea. Wall paper is a huge pain to remove correctly, and that glue will absolutely cause problems with future coatings if it's not dealt with.
I have 2 suggestions.
  1. If you can muster the willpower to clean the walls one more time, get some TSP (trisodium phosphate, the real stuff, not the "TSP Substitute") and use it mixed with hot water to really scrub, then rinse with water. It does a good job of eating up that gunk.
  2. Use an oil primer. As good a product as Gardz is, you absolutely must avoid any kind of water based product being directly in contact with the remaining paste residue. The water can re-activate it and cause poor adhesion and peeling. If that base coat doesn't stick, anything else that goes on top of it will fail sooner or later. Get a respirator with an organic vapor cartridge, a can of mineral spirits... and maybe a couple of fans. It's kind of a pain, but it dries fast. It's really not that bad.
Also, @JACK makes a good suggestion in the comments to deal with the texturing, but I will add a warning: don't mud directly on top of the unprimed wall, for the same reason I recommended not using a water based primer.
  • Gardz will be better than oil.it is designed to seal over glue residue. It penetrates deeper since it is thin and dries slower.
    – Kris
    Aug 15, 2020 at 21:59
