We’re in the process of renovating an old farm house with a old section and a new side.
Because the house has a hydronic heat system we are looking to convert to underfloor heating throughout. Right now it’s a mix of forced air in the old part of the house and underfloor Heating in the new.
We just hit a bump though, having discovered that all the 2nd floor rooms have lead painted floors underneath a plywood subfloor and then a laminate or engineered flooring (depends on the room).
We plan on keeping the old board sealed under a newer floor, but should we look to remove the paint first? Will the underfloor heating cause the paint to off gas or something?
Thanks,
    Generally, lead compounds are not volatile. As long as installing underfloor heating doesn't create access to the paint, and does not create dust during installation, it should not be a problem. Check local codes, though. Commented Aug 14, 2020 at 22:52
Lead melts at 621°F. Fumes are released at 900°F. Your in-floor heating and floor are going to be at temperatures an order of magnitude lower than the temperature you need to create off-gassing.
You should be safe.
  • Why do you assume that the paint contains elemental lead?
    – DJohnM
    Commented Aug 15, 2020 at 6:54
    PbCrO4, and Pb3O4 are the lead states that would most likely be present within the paint. They both have even higher melting/boiling points. I gave the "worst case" scenario and even the "worst-case" is quite acceptable.
    – ziptron
    Commented Aug 16, 2020 at 1:34
