Could I get some help identifying this blown (and very smelly) capacitor from a ceiling fan, and maybe suggest where replacements may be found?
I'm not sure how to read the label. Also there is no wiring diagram for the 3 wires, although two different capacitances are listed.
  • AC300/260V. What are the two voltages, and is it necessary to match exactly for a 120V AC circuit?
  • 1.5 / 3 uF J. How can I find out which wire is for 1.5 uF and which is for 3 uF, short of measuring. What is the J at the end?
  • TV525/455. No clue what any of this means. Is it relevant?
  • What is CJ 2WS?
  • What is the purpose of this capacitor? Is it really necessary for operation? When capacitors fail do they fail open or shorted? Aug 13, 2020 at 1:27
  • @JimStewart -- it's a motor run cap, and it could go either way Aug 13, 2020 at 1:29
  • @ThreePhaseEel , my old, heavy Hunter 2-speed oil bath fans have been in service for 40 years and never been serviced. Do these not have capacitors? The capacitors in my a/c condensing unit have been replaced multiple times but in my air handler never AFIK. Why the difference? Aug 13, 2020 at 1:42
    @JimStewart I don't have a circuit diagram or know the specific purpose, but from searching online it seems fans have a "start" capacitor which helps build torque when the fan is turned on, and when this capacitor dies (apparently a common problem), the fan will make a humming/buzzing sound and fail to turn, turn very slowly, or switch directions on its own. That describes the issues with this fan.
    – adatum
    Aug 13, 2020 at 1:50
  • It is a run cap the op said it changes directions when blown so if 3 speed 1.5 , 3 and both in parallel 4.5 UF will provide the 3 speeds. When caps are bulged quite common with electrolytic caps they shorted and blew up basically. Oil filled rarely blow last forever but cost many times more and are larger. I hope that helps @jim Stewart
    Aug 13, 2020 at 7:21
It is a 1.5/3 microfared cap 260v eBay has them for 8.99$ Amazon 6.95 the one that I looked at was 250v but that will be fine on a 120v circuit. You need to make sure you connect them correctly as 1 lead is common 1 is 1.5 UF the other is 3 UF.
The positions will be the same , the other numbers are MFG lot numbers etc.
Note I just searched “ capacitor 1.5/3”
  • Considering the capacitor is blown, how can I find out which is 1 uF and which is 3 uF? Thanks, I had already seen the ebay and amazon listings for 3 wire 1.5/3 uF capacitors. I'll see if they can be found locally, otherwise those are the only options I've found.
    – adatum
    Aug 13, 2020 at 14:59
  • The physical location on the devices is usually the same, if you have a capacitor checker on a volt meter check one may be good the single wire is or has been the common on every one I have replaced. But changing wire for wire should get you there ie common on left cut the front right out and connect your new front right then the rear.
    Aug 13, 2020 at 15:07
  • In the worst case, yes, I'll just use the same physical wire locations and hope for no magic smoke. My multimeter can measure capacitance, but I don't know how to figure out the existing configuration with the dead capacitor.
    – adatum
    Aug 13, 2020 at 15:37
  • Come on I just told you the single wire is the common the 2 wires on the other end are 1.5 & 3 UF leads Mark them so you will know front and back.
    Aug 13, 2020 at 16:46
  • amazon.com/HQRP-Capacitor-Hampton-Ceiling-Coaster/dp/B01N6O1EBW This capacitor and the positional wire matching worked, with the 1.5uF purple/left wire joined to the fan's black wire going to the switch, the 3uF yellow/right wire to the blue wire also to the switch, and the single grey wire to the other black wire going to the 6-pin wire harness. No magic smoke, and the fan is working again. Thanks!
    – adatum
    Sep 4, 2020 at 4:11
