I'm looking for help on planning a roof over a deck I plan on adding to my house. The roof will be 18' wide and extend out 12' from the house. I want to have at least a 1' overhang on each side making the roof 12x20.
I plan on using polycarbonate sheets as roofing so it does not need to support much weight. Building in a location that does not experience snow. What size post and beam do I need to use to span the 18' between support posts?
Here is the concept design.
Deck Concept Photo
  • Welcome. I've attempted to simplify your post to remove non-essential information. Feel free to revise further to clarify anything.
    Aug 12, 2020 at 15:11
  • There are folks here willing to do this for you (and they'll probably be along shortly), but here are some things that might help you: google.com/…
    Aug 12, 2020 at 15:26
Truss span is what you look up. A 2" by 10" 16" on center will work for 20 ft 8 inches. With a 3/12 pitch. Less than that changes it to 19 ft 9 inches. If you include a ceiling of some sort then go 12 inches on center. The dimensions I noted are found in many places. But the best location is the International Residential Code for rafter size R802.4.1 R802.4.1(1) through R802.4.1(8). This goes through types of wood and a few other variants. Snow loads in northern areas are in the local codes. Usually decreased spacing. But you noted No Snow so not an issue.
  • You're saying that the snow load makes no difference to the strength requirements for a roof? Especially a fairly flat (3/12) roof? I'd suggest that you edit your answer to include some code references that will support this, as it goes against most information I've seen and common sense.
    May 20, 2022 at 11:14
  • Yes I guess I could have been more clear. In retrospect I should have left the wording out on snow. A 3/12 roof is not suggested for areas with snow although done with trusses designed for the area snow loads. Examples are flat roof commercial buildings. The dimensions I noted are found in many places. But the best location is the International Residential Code for rafter size R802.4.1 R802.4.1(1) through R802.4.1(8). This goes through types of wood and a few other variants. Snow loads in northern areas are in the local codes. Usually decreased spacing. May 20, 2022 at 13:55
  • Please edit that info into your answer. It helps with discoverability (not everyone reads comments) and comments are ephemeral - they can get deleted.
    May 20, 2022 at 14:05
  • Done.Thanks for the suggestions. May 20, 2022 at 15:32
