I am trying to replace a broken hidden furniture hinge and cannot find a hinge that matches. How does one find a specific atypical hinge? The following pictures are of a not yet broken hinge. hinge open
hinge closed
I think your best bet is to look into woodworking stores. Machinery, specialty cutters/blades/etc are what they are known for, and many even deal in furniture hardware. Maybe checking a place like Rockler should be able to point you in the right direction if they cannot help you out directly. A simple Google search for woodworking stores and hidden hinges should also give you a pretty good start.
  • An old-line hardware store might well have a catalog of weird hardware they can get, if they don't have two or three in a drawer someplace. But many have been driven out of business by competition that won't be able to help with such things.
    Aug 11, 2020 at 2:11
If that is the only door with those type of hinges, or since it is somewhat concealed, what you have is a variation of a no-mortise hinge. The main difference between yours and a standard off the shelf no mortise hinge is your allows the pivot pin to go behind the edge of the door, where the standard ones have the pivot outside the edge. This will mean you will need to replace both hinges so the hinge pins line up.
enter image description here Picture courtesy Hardware Source
