3 way switch 1 3 way switch 2 existing lights controlled by 2 way switches main electrical panel
I currently have 5 lights controlled by two 3-way switches.
Not sure if this is relevant, but the above exists in a partially finished basement(Ceiling and two walls exist). I am completing the other two walls and will be running wires, adding outlets etc.
I intend to achieve the below configuration :
  1. Make an existing 3 way switch to single pole that controls 2 lights
  2. Make the second 3 way switch to single pole that controls 2 lights
  3. Add a new switch(single pole) to control 1 light
Any ideas on how I can achieve the above configuration will be appreciated. Can add any other relevant information that may be required.
Thank you
    Post pictures of the existing 3-way switches showing all wires/cables. Do not disconnect anything. – manassehkatz-Moving 2 Codidact Aug 10 '20 at 15:04
  • Can you post photos of the insides of the boxes for the existing 3-way switches please? – ThreePhaseEel Aug 10 '20 at 22:50
