I posted Shower diverter turns but doesn't divert a while back about a diverter that turns but won't divert. Thanks to the community I learned some terminology and that I needed to open up the hole to get a wrench in there.
Well I used a dremel bit made for ceramic to open the whole enough to get a nice wide (1-9/32) wrench in there. And I turned and got this nut out the nut that came out
Behind the nut seems to be just a single piece. Is there something I can take out and replace here or do I need to remove the entire valve? (which screws in 4 ways and would require removing quite a bit of tile I think) behind the nut
update: i've now lost the nut inside the wall :-(. i turned the water back on and it's not leaking (yet?) so i guess that's good...
  • Time for a bore scope and grabbers or a paper clip to retrieve the nut. I picked one up at harbor freight a few years back and it has been a handy tool. – Ed Beal Aug 14 at 5:58
