The very end of the fiber board strip, which you can't see behind the trim, has worn down--there's a hole in it--and water from rain gets into the garage there.
Everywhere else, the strip is fine so what can I do to properly fill in the hole in the strip?
  • The photo is not showing us the problem. A closer look may help. Is the felt strip a filler in the expansion gap of the concrete slab ?? Or a gasket attached to the door or slab. ?? – Alaska Man Aug 9 '20 at 16:09
  • @AlaskaMan The problem is that there is a hole dug into the felt letting water in. – Rob Aug 9 '20 at 16:10
  • Rob, i understand that. I was saying that the photo does not show us the hole. More info on the strip and how it attached would be helpful. – Alaska Man Aug 9 '20 at 16:11
  • Is that a threshold? That is falling apart , kind of hard to see. Is that a “man door” or a large roll up, swing up door? – Ed Beal Aug 14 '20 at 14:42
