I am replacing a 4-inch spread faucet. The hot and cold water taps each have a big brass nut threaded under the sink (in addition to the basin nuts). These nuts are connected to each other by something I’ve never seen (I’ve only done about a half dozen sinks in houses I’ve had). I don’t know how to remove the piece connecting those nuts so that I can remove the nuts.
1Can you add a picture from the top? Given the prominent "front" marking on that I suspect the whole thing pulls out the bottom, perhaps after undoing something above so that can happen.– EcnerwalAug 8, 2020 at 22:54
Added a picture from the top.– WyattsTorchAug 8, 2020 at 23:11
We should close the question if the answer the op provided is deleted that doesn’t make any sense.– Ed BealAug 9, 2020 at 15:27
1 Answer
This was a bottom-mount faucet.
I was able to pry out a plastic ring holding each side, and drop it down from the bottom.
See the hot water side in the picture.
A small screwdriver easily fit in the notch.
So the moral of the story is; A small screwdriver was required to get your big brass nuts off ? Aug 9, 2020 at 17:19
