I'm installing a range hood over my island after a kitchen remodel and I ran into an issue. If I try to run the ducting alongside the joists in the ceiling I run into a beam which looks to be supporting the sunroom which extends beyond the kitchen. I've included a picture of the kitchen layout below with an annotation showing the location and direction of the beam and an illustration of the direction of the joists (not to scale). To be clear there is a second floor above this one so I can't just go out the roof.
The beam and joists are 14" deep. I am concerned about drilling a 6" hole in the beam and perhaps a second one which is behind it. Is that acceptable? The range hood I have will not accommodate any reduction in diameter. The beam appears to be solid wood and a picture is shown below (looking down the hole in the ceiling along the joists.
An alternative route is for me to go a shorter distance through the joists and out the side of the house. The joists are engineered wood TJI 230 14". Now according to the manufacturer, I can drill a 6" hole through the web no problem since I am far enough from the ends and there are no other substantial holes in the ones I've looked at so far. My only concern here is that contrary to what I am reading from the manufacturer, everyone seems to be telling me that I shouldn't make a hole any greater than 1/3rd the depth of the joist, and that if I do that I need to re-enforce the hole. But I don't see this mentioned anywhere in the manufacturer's guidelines. By all indications it is perfectly acceptable to make a 6" hole in the joists.
Can anyone provide me feedback: am I okay going through the beam? Alternatively, can I go through the i-joists without re-enforcement? Does the 1/3rd rule not apply to engineered i-joists like this?
Thanks!
  • Welcome. Excellent, Nicely done for a first question.
    – Alaska Man
    Aug 8, 2020 at 17:30
  • "everyone seems to be telling me that I shouldn't make a hole any greater than 1/3rd the depth of the joist" -- do these people know that you are talking about engineered wood joists, not regular dimensional lumber? The issues are very different. Aug 8, 2020 at 19:05
  • In my understanding, beams are not to be messed with in any way like you need to get that duct through. I-joists, no problem as long as you follow the makers guidelines. This is left as a comment since I do not know all the parameters of drilling or cutting large holes in LVL beams
    – Jack
    Aug 8, 2020 at 20:09
When I got my first car, my Dad said, “GM builds ‘em, tests ‘em, and tells you how to maintain ‘em...so follow ALL the maintenance rules.”
I think that applies here. They know what their I-joists can withstand. I’d follow it carefully.
The one thing that causes problems seems to be when installers get in a hurry and “eyeball” cuts, etc. id carefully layout the holes and use a SHARP saw. You want it cut perfectly. No tearing of surrounding fibers.
Remember, there is a “safety factor” the manufacturers use and you don’t want to cut into that.
Note: Now you’ve got to be careful of any additional loading (like waterbed, refrigerator, etc.) from the second floor that could affect the manufacturer’s normal design criteria.
For cut timbers there are dozens of things that can go wrong, so I’d get a structural engineer or architect to lay it out, but for I-joists I’d follow their instructions.
  • I think the OPs main concern is the LVL beam that is pictured. It is a presumption that it is an LVL since it is glossy in the pic and typically LVLs are used for beams in this application. According to my reading, he was asking for confirmation about the TJI's. Your assertion that he needs to follow the install guides is spot on.
    – Jack
    Aug 8, 2020 at 20:12
