Winter is coming. I plan to stick soft polyethelene foam on window glass for thermal insulation. Last time I use Styrofoam glue, and it is a disaster. It is hard to remove it. It take hours with alcohol and box cuter. Is there any proper material for the job? The house is rented. In future I will have to remove it. I am looking for a glue strong enough to keep polyethelene foam and glass together, removable in future, and leave no gap. I tried gap before, if foam and glass has a gap between, moisture condenses and molds. I wonder is 3M 77 spray adhesive will do the job? It sticks like a 3M post-it. Or is there any alternative? Thank you!
1that looks like polyethelene foam not polystyrene.– JasenAug 7, 2020 at 12:33
1super77 is neat stuff, basically post-it-in-a-can I don't think it would work well on a rough surface like the foam in the picture,– JasenAug 7, 2020 at 12:38
2Why do you need soft foam? How about XPS sheet thick enough to hold its form? Gives much better insulation too. Remember a small, stagnant zone of air such as 1/2" to 1" actually adds insulation value, so you don't need to seal up hard against the glass to get best insulation performance. That's how double-pane windows work.– Harper - Reinstate MonicaAug 7, 2020 at 18:03
Yes it is a polyethelene foam . Also, I tried leaving gap before. Moisture condenses and foam molds.– SuperuserAug 11, 2020 at 5:16
Because foam is light, do you think it is possible that super 77 will hold? Also, I will cut a perfect size to fit in frame, so weight will be hold by frame, and super77 just need to vertically stick to each other.– SuperuserAug 11, 2020 at 5:27
Small dabs of clear silicone caulk. You'll have to secure the foam while the silicone cures (maybe 4 hours), but it'll hold very well and will be a breeze to remove and clean up. You could use masking tape or lean a broom against it. Start with pea-sized dabs, and leave them round until the foam presses into them. Keep them away from the window frame for easier removal.
Double-sided foam tape. This would be fast and easy, but it would leave a small gap against the glass. This just means that you'll need to seal the foam well at the edges. Rope caulk could help with that. A few squares around the perimeter should do nicely, or you could seal the entire edge.
Thank you very much, but I need to confirm with you about silicone caulk. At edge of glasses silicone is already used to stick glass to frame. It is strong. Is it really easy to remove? Also, I tried gap before. Moisture condenses and foam molds. Aug 11, 2020 at 5:18
Because this application of polystyrene has been so problemmatic, have you considered thermal liners/draperies, or applying long sections of large sized bubble wrap, which only require spritzing the glass lightly with water to cause the bubble wrap to tightly adhere to the window panes? Either remedy should afford better insulation with less work.
I'd try regular white PVA glue, paint the foam with glue and allow it to dry overnight, then dampen them with a little fresh glue and press them on the glass.
it should stick and hold there
when you are done it should just peel off
I painted only the foam and that is still sticking (after only two days), but painting the glass too could be even better.– JasenAug 14, 2020 at 7:00
Glass is hard to glue to, since it is such a glossy surface. Generally effective glues will be the "sticky forever" kind that behave like gum.
The problem is, UV light will be your enemy. It is going to modify almost any glue you could use, into a brittle, deteriorated haze of a mess to remove from the window.
One important concept about insulation is that narrow air gaps are not your enemy. Consider how a double-pane window works. When airspace is narrow enough (less than 1 inch), it stops convection from operating in that space. The air actually becomes a pretty good insulator. Another insulation that uses that concept is fiberglas; the strands don't insulate, they just add friction to keep the air from moving freely. The air does the insulating; that's why compressing fiberglas hurts its insulation value.
As such, you should not be afraid at all to leave a 1/2" to 1" gap. Trying to conform the foam tightly to the window and frame is actually working against yourself.
That opens the possibility of using rigid products such as XPS or polyiso foam, which simply span the window, and are affixed at the edges. They have considerably greater insulation value than any of the sheet foam you have been looking at.
That said, don't forget about the impact of window air leakage. If the window is drafting, it could push the air through that intentional gap, defeating its purpose. So address any leaky window gaskets. Keep in mind old windows weren't built to be drafty; they were built with competent seals, whose maintenance has since been neglected.
Thank for your comment. I tried gap before. Moisture condenses and foam molds. So I really need to stick whole foam surface to glass. I have edited my post about the gap. Aug 11, 2020 at 5:28
This is an ideal case for hot glue. It holds plenty strong, won't break down much in UV conditions, and is cheap and widely available. Clean the window and foam before applying for best adhesion.
You can probably just yank the foam off when you move, but if it's vacuumed on good, a hair dryer can be blown on both sides to heat it enough to soften the grip. Once the foam is removed, any globs of leftover hotglue will easily pull or scrape off without leaving something messy that needs solvents to cleanup.
Thank you for your advise, but it looks like hot glue leaves a gap. I tried gap before. Moisture condenses and foam molds. So, I really need to stick whole foam surface on glass. Aug 11, 2020 at 5:21
