I'm trying to finish up our shower. We ended up using a Tile Redi (which was an ordeal, but that's another story...) which means that the pan, itself, is completely waterproof, and that the tiles are epoxied to it.
For the shower floor, we used hexagonal tiles and grouted them.
For the curb, we decided to go with large format slate tiles. As such, we have only a few gaps to fill (2 vertical, one horizontal) along the entire 5' curb. As the gaps aren't large, I can't use sanded grout and it occured to me that this might actually be a lot easier to just caulk. They are (nearly) black tiles and I'd use black caulk.
Is there any reason NOT to do this? As the curb won't be getting much direct water, I'm thinking caulk will last just fine on it.
I would not use caulk on this. Grout provides strength to the tile, especially the corners and sides. Using a unsanded epoxy grout would be your best bet since it's waterproof and doesn't need to be sealed. It can also be used on plane changes, vertical to horizontal surfaces. Caulk never goes on as smooth as you'd like it to whereas grout does. It will probably be faster to grout than caulk and unlike caulk, the grout will probably last as long as the tile.
  • Epoxy grout is the best in this location it will last longer than calk and provide support for the tiles.
    Aug 7, 2020 at 17:04
