What is the solvent that will dilute the non-cyanoacrylate clear Gorilla Glue?
To know what may dilute this glue, we would need to know what the ingredients are (if not cyanoacrylate), and then this might be more suited to chemistry.stackexchange.com – Sam Aug 5 '20 at 19:10
3You're asking about diluting glue, which would imply that you need it thinner for some reason. Is that correct, or are you asking how to clean up hardened glue? – isherwood Aug 5 '20 at 19:24
Add a comment
Acetone or denatured alcohol will dilute and dissolve liquid urethane glue. However, they may not work on hardened glue. There are no practically-available solvents for that. You're left with mechanical removal of the crusty material.
