we can not find the transformer, I read that i can also replace the G4 lights directly?. I would really love some help
    Hello, and welcome to Home Improvement. We aren't going to be able to find the transformer either; perhaps some pictures and diagrams might help us? And, you should probably take our tour so you'll know you'll know the details of contributing here. – Daniel Griscom Aug 5 '20 at 16:11
    What is the voltage of your G4 lamps? I have some 120v they would not require a transformer. A solid state dimmer would be all that is needed in that case. – Ed Beal Aug 5 '20 at 16:45
    The make/model of the light fixtures might help someone determine if you can safely replace the bulbs only or if more work will need to be done. Maybe with a couple of pics of the lights themselves someone might be able to give you an idea of where to look. Will VtC if no edit with additional info – FreeMan Aug 5 '20 at 16:46
  • What do you use for bulbs at the moment? – ThreePhaseEel Aug 5 '20 at 23:42
  • hi , the bulbs are G4 12 v 20 W. – sofia ansaldo Aug 6 '20 at 15:39
