I recently removed a closet in our main living area and one of the closet walls contained an AC supply vent. This left a 4x12 hole in the floor where the old stack head was removed. While we could just buy a flush floor register cover before our floors get refinished tomorrow, I'd rather relocate the vent in the remaining wall next to the previous vent location.
I measured between the remaining closet wall studs and I'd have enough space for a 4x10 stack head (so a bit smaller than the old one). This leaves me with a couple of questions:
- Can I trim the circular ducting beneath the subfloor back so I can fit an end register duct boot to the new location? Or do I need to replace the existing ducting with a shorter length and then attach the end register boot?
- Will it cause issues if I relocate the outlet in that space to the opposite side of the stud it's currently attached to to make room for the new vent, or is placing an outlet that close to an AC register a bad idea?
