As you can see the screw on the right side is hanging in the air right now . What should I use to fill the hole and screw them back in? Thanks! enter image description here
  • Can you tell what the screws are screwed into?
    – JACK
    Aug 3 '20 at 20:30
  • i think I see the top of a zinc screw-type drywall anchor behind the other screw.
    – Jasen
    Aug 4 '20 at 8:00
-1
These work best if the screws are driven into a wall stud vs. a hollow-wall anchor. It's not clear what you have going on here, but if it's an anchor, or just a screw driven into drywall, then you should relocate to a spot where you can hit the stud.
Patch the hole with some spackle and if needed, you might need some backer as this looks to be a fairly large hole.
  • 4
    I think a railing that is not anchored in studs is just for decoration.. Aug 3 '20 at 21:05
