In several areas around this house (a ranch on slab), the clapboard siding comes right to concrete walkways, resulting in peeling and rot.
Short of ripping out the concrete, is there a less destructive solution?
Further, how could this ever pass for responsible construction?
  • It isn't responsible construction.This type of detail goes on too often by too many builders.
    – Jack
    Commented Aug 3, 2020 at 0:17
If the height of the door to the bottom of the siding is any clue as to how high the floor slab is above the outside concrete, The siding could have been kept above the concrete perhaps 1" and still would cover the floor slab for weathering.
This will be an over-simplification, but to fix it, I would carefully cut the siding 4 1/2" above the concrete, add flashing, and insert a piece of 1 1/2" X 3 1/2" PVC material as a "frieze board" to replace the rotted siding. If you re in a temperate climate, like the new england area the PVC will move a lot so it may be best to use a wood product that is primed on all sides, including all cuts. Installed so when it is raised to meet the flashing, it provides a 1" gap to the concrete.
  • thanks for this tip. If I hired out, what type of contractor would be best?
    – Scott
    Commented Aug 9, 2020 at 19:04
  • I would try a siding contractor with references. They need to know what they are doing, if they don't it will be a bad situation gone worse because they will simply cover the bad areas and not weatherproof to fix the issue.
    – Jack
    Commented Aug 9, 2020 at 20:57
