I have an older GE electric stove: there are 6" & 8" burners.
If you set the heat to max the elements each and every one glow cherry red and you have to watch food to make sure it does not burn.
But below the one or two highest settings the burners not only don't glow; they don't seem to produce much heat. So they produce what I consider accurate heat, but only at the very highest settings.
I think the burners are old; should be replaced.
Is there an acceptable resistance value, that if I were to test the burners with a DM I could determine if they are defective/failing?
Thanks for reading
