In the home inspection report, it was stated that: "a Qualified window contractor to correct as determined necessary the master bathroom window in the shower has no tempered etching. (should have safety glass)"
The location of the current non-tempered glass window is 5'3" from the shower floor. The window size is 2'10 5/16" x 2' 9 3/4". The window is original from 2017 brand new construction. If this requires tempered glass, kindly share with me the specific section in the code where it states this requirement. Thank you.
