I was looking at battery power tools and their different battery voltages. Some of the voltages are listed twice, with and without "max". An example for mowers is "40-volt" and "40-volt max". What's the difference between the voltages with "max" and without "max"?
What brands are you looking at it may have something to do with the style of the battery contacts , I have a 6 ah battery that the contacts look the same as the 2 ah batteries the difference is each cell is larger. – Ed Beal Jul 29 '20 at 17:22
What website is this? Most likely those categories are just echoing the text in the advertising blurbs for the products found. It's possible, tho' a bit unlikely that, e.g., a "40 V max" tool would function with a 24-V battery, but my guess is just poor English. – Carl Witthoft Jul 29 '20 at 17:45
@CarlWitthoft Lowes. – Ghostship Jul 29 '20 at 18:04
This isn't a question about batteries. This is a question about a website's search engine. There are a variety of reasons to allow ranges in search filters. – Harper - Reinstate Monica Jul 29 '20 at 18:42
@Harper-ReinstateMonica not sure I agree with you. I pulled up the Lowes site and "20 volt max" yields a set of 7 brands, while the "20 volt" yields a different set of 7 brands. "Max" is all about marketing 'cause "Max" sounds... maxier... – FreeMan Jul 29 '20 at 19:26
There is one brand of "20-volt Max" tools that reasonably clearly state on their packaging something to the effect of:
Battery provides 20 volt maximum starting power. Provides 18-volts in use.
As a matter of fact, they'll sell you a simple physical adapter (and some wiring between the contacts) that will allow you to use the "20-volt max" batteries on their older 18-volt line of tools.
TL;DR:
"Max" is 98.475% marketing because "Max" sounds, well, like more than "not-max". (And 99.238% of all statistics on the internet are made up on the spot.)
Presumably that "20 V starting" is the rating of their battery, not the tool's draw. – Carl Witthoft Jul 29 '20 at 17:46
1Yes it is, @CarlWitthoft. I don't remember the exact wording at the moment and can't be bothered to go look at the DeWa... (oops) site right now to get it. :) – FreeMan Jul 29 '20 at 17:47
3The "20V" claim is entirely bogus. Li-Ion batteries have a cell voltage of 3.6V nominal which divides evenly into 18V (i.e. 5) but not into 20. So there is no way to get 20V out of a 5S battery pack which these "Max" cells are. It's marketing hype! – jwh20 Jul 29 '20 at 19:30
