I just bought a home and discovered a substantial amount of wood rot in the garage. I had to tear away a lot of drywall to see it, and when I did, I found obvious evidence of carpenter ants. However, there are no ants left, no corpses, the entire colony seems empty.
Now, our contract with the sellers clearly states that there have been no pests or wood destroying organisms in the time that they've owned the home, but I don't believe that at all. They've been there for 33 years and have made modifications to the garage, including adding insulation and drywall (dated 88 and 2001 respectively) and building a second garage that adjoins to the first in 1994. I find it extraordinarily difficult to believe that the rot I'm seeing has been present for over 33 years, it seems to me that it should be far worse by now if that was the case.
This picture shows the rot in the corner of the garage, which is adjoined to the addition garage from 1994. If the owners were being truthful, I'm to believe that they built this addition with pest-induced rot so bad that you could see daylight through the siding? Sounds absurd to me. They even reinforced (poorly) the structural members. That concrete is also only in the corner, the rest of that wall has wood right on top of the dirt. enter image description here
Clearly there have been repairs done. It's a question of whether or not there was an infestation during their period of ownership, which brings us to these holes in the drywall (this is the same wall as the previous photo): enter image description here
You can see another one to the left where I removed the drywall, but it's the same kind of hole. This to me looks suspiciously like some kind of hole for gassing or otherwise injecting something to kill the ants. (the fan in the middle is some exhaust to outside and I figure is unrelated)
This is an up close shot of the white junk that was injected into the hole. enter image description here
Obviously I'm consulting professional carpenters and exterminators, but does anyone have any experience with this kind of thing? If this really is obviously a treated infestation then I'm planning on getting some kind of statement from an exterminator and/or carpenter and pursuing legal action. I'm not sure if the sellers lied or just messed up their contract and didn't understand what they signed, but they're still on the hook in Washington state if they improperly disclose defects.
Some other shots showing clear evidence of a carpenter ant colony: enter image description here enter image description here
Thanks!
  • See if you can get the white material tested Aug 28, 2020 at 10:59
That is termite damage. I had one termite attack where they combined with ants ; I did not immediately get rid of the ants because I understood they would not coexist with termites. That is pretty extensive damage, I would replace all wood with damage. Apparently a repair was made by squirting in expanding urethane foam ( such as "Great Stuff"). I have had 2 termite attacks and a few cases of dry rot and recognize the difference. And carpenter ants chewed some of the Styrofoam out of my insulated garage door ; the wonders of Texas.
  • Interesting, I thought that colony looking thing in the last picture was from ants. It has the consistency of sawdust, touch it and it falls apart. In any case, I'm thinking it's damn near impossible they left without being driven out. It's not like termites go, oh hey, this neighborhood is boring, let's move somewhere else. Jul 29, 2020 at 1:06
  • Ants may have lived with the termites, as I saw. They were removed with insecticide. Jul 29, 2020 at 15:48
