I'm trying to find studs on an exterior wall of a recently (10 years?) renovated house that I'm renting. I've had issues before where the studs in a wall seem to be a bit wonky - irregularly space, sometimes studs that don't go all the way up to the ceiling, etc. I also have problems where my stud finder will think there's a stud, but when I screw in there, it turns out there is no stud.
Fast forward to today - I'm trying to hang some curtain rod holders over a double-door to the outside on an external door. I found one stud to the left of the glass door, but I'm struggling on the right. My magnet stud finder found one down low, but it doesn't seem to go all the way up. And my other-kind-of stud finder, gives me unreliable lights when I run it across the top of the wall looking for one. It has hinted at a couple of places that turned out to be empty behind the drywall.
And, oddly enough, there don't seem to be any above the door frame - though when knocking on it, that part of the wall sounds solid (as opposed to the hollow sound you get on most walls).
So my question is this - when contractors are doing renovation work, and may be adding extensions or things like that, are there any rules of thumb for how they build things out? Are there times when the studs above a door frame would be differently spaced than those below? And are there any other kinds of wall construction that would lead to me finding so many frustratingly non-standard walls in a recently renovated house?
For what it's worth, here are 3 pics of the inside wall (since a single photo is all washed out due to the light from the door), and one of the outside.
Left side of door Center view over the door enter image description here The wall from outside
  • The reason you're not finding a hollow sound above the door is because there's a solid header above it. See the pics below. That's how it should have been framed. Use Jon's tip about using small nails to ensure that you do have solid wood where his pic shows it should be, then go to town with the mounting screws.
    Jul 29, 2020 at 13:08
Since it's an exterior wall, you may have "cross strapping". It's a technique to frame a wall using 2x4 studs, and then cross strapping it (horizontally) with 2x1 straps to increase the space for insulation.
In this case the drywall is fastened to the strapping, and the fasteners will be aligned horizontally, rather than vertically along studs (see drawing).
They could run 24in or 16in apart (vertically separated)
From https://www.nrcan.gc.ca/energy-efficiency/energy-efficiency-homes/make-your-home-more-energy-efficient/keeping-heat/keeping-heat-chapter-7-insulating-walls/15641
If this is your situation, you would likely not be able to use the straps for hanging curtains: there will likely be no strap where you need one, and they are not for bearing a load.
The solution is to use longer (2.75 - 3in) and stronger screws (#10) to reach deeper to an underlying stud or header.
The best bet for locating the studs is at the edges of the window opening. That's where you'll find the "king" and "jack" studs (see drawing).
The stud finding techniques in the other answer, by Jon, are indeed good, but with strapping it's still hard to get reliable results from either.
Also, a stud finder with "deep scan" might or might not work. I've had no success with one.
If you are ok with a bit of drywall filling, you could carefully drill a 0.25in hole through the drywall and poke through it with a 3in nail, coat hanger etc.. to see if you hit a stud after the strapping space of about 0.75in. There will be insulation to contend with: and becareful not to twist out insulation or vapour barrier that gets caught on the drill.
If you are worried about punctures in the vapour barrier after all the drilling, you can squirt in some expanding closed cell foam through each hole, to re-seal them, before you patch the hole.
  • Agree with you 100% about finding king/jack studs at the edges of openings. Assuming the work was done properly...
    Jul 29, 2020 at 13:06
  • @FreeMan, yes, poor workmanship can obscure good technique. Let's see how far the OP gets with this. There are two answers to help them along.
    – P2000
    Jul 29, 2020 at 18:07
  • Looks like it may indeed be cross strapping, since I couldn't find any studs up high on the right side. So I ended up just using drywall anchors on that side, and am counting on the fact that I hit a stud on the left and some header board for the middle. Thanks!
    – Doug
    Jul 29, 2020 at 19:41
  • Awsesome @Doug, I ran into the exact same problem in my house. Glad it was helpful. Anchors should work, but with all the yanking at the curtains watch out for drywall crumbling. You could mix a bit of "setting compound" (not topping compound) and smear it into the hole and around the anchor.
    – P2000
    Jul 29, 2020 at 20:05
Take it from me, you cannot assume the last guy that worked on your house cared about any rule-of-thumbs or that they didn't do something unexpected.
Above doors, sometimes there are cripple studs and sometimes there aren't - they are very short so they might be hard to locate with a regular stud finder. Sometimes there is just a header:
door opening with only a header
The header is sometimes not flush with the studs around it and can be indented half an inch or so.
You've already identified the tried and true method of knocking to find studs but what else can you do to find studs? Well assuming that your drywall is screwed into studs, you can attempt to find the drywall screws with a super magnet - I've had a lot of luck with this method.
Another thing you can do is remove the base board and pound tiny nails into the drywall until you hit a stud. If the stud doesn't go all the way to the ceiling like you said, that's annoying and there isn't anything you can do about it now.
I've also used tiny brad nails as a kind of pilot for where I think the stud is and where I want to put in a larger fastener but I just want to check first. If I'm off, well then I only leave a small nail hole in the wall instead of the larger fastener hole.
brad/wire nail
  • Thanks for the pointer about header boards. It looks like cross-strapping is causing problems for some of it, but there does seem to be solid wood above the door that I could anchor my middle one in to. Thanks!
    – Doug
    Jul 29, 2020 at 19:42
