I installed this "click" vinyl, but there's one corner of my floor(concrete) that's uneven, because of that the vinyl doesn't click properly and there's a small gap.
Can I just caulk this gap or do I have a better option here?
  • It's possible, POSSIBLE, a heat gun might soften the vinyl enough to make it click together. You can test on scraps you may have. – Steve Wellens Jul 28 '20 at 14:11
    I'm not the expert, but I'd think that fixing the underlying floor would be a far better solution than applying a band-aid on top. – FreeMan Jul 28 '20 at 14:12
  • I don't understand. Are you saying that you can't assemble the flooring panels because there's a hump in the concrete subfloor? Sure, you can caulk the gap, but it'll look like a caulked gap and not proper flooring. Maybe revise your post to ask about the actual problem rather than this symptom of it. – isherwood Jul 28 '20 at 15:05
  • If it's a "bump" you may be able to grind it down. Otherwise you'll need to level the entire surface. Usually a flowable leveling product is used for this purpose but it's generally beyond the capabilities of a DIYer. – jwh20 Jul 28 '20 at 15:16
