(From my earlier posts, you may have learned that I had several different bibs cause several different floods in different parts of my house. Each instance posed its own unique challenges. This is a post about spigot number three.)
The following picture shows the spigot from the inside though an access hole:
It looks to me like I should be able to screw the spigot out but I wasn't able to do it due to resistance and I gave up for fear of causing greater damage. Am I correct that I should be able to screw the spigot out and, if so, are there some safe tricks for loosening the connection?
