We are buying a new house, and I was curious about this junction box. It has several lines of coax and cat5e in it.
Each room has a blank plate, and behind it is a coax and a cat5e drop.
I was assuming that when we get Comcast,I could put the modem in this closet, with a router and switch, put ends on each Ethernet cable, and have wired connection in most rooms.
But then I looked closer and realized that 6 of the Ethernet cables are wired to 2 other Ethernet cords, using only 2 wires from each cable. Any ideas as to what this setup is?
