I am just starting to build a deck. I dug the holes for my posts. I live in Michigan, frost line is 42". I dug down to 48" with the intent of putting a 6" pole barn biscuit to use as the footing.
In 2-3 holes, they immediately filled with water after getting to depth. I'm not sure if the water table is just super high, or what's going on. It was not rain related as everything was dry during this time.
As I understand it, as long as the water is pooling under 42", it shouldn't be an issue. It's below the frost line, thus won't freeze. It's at the footing height or under, thus won't deteriorate the post.
Is that correct understanding? If for some reason the water is pooling above 42", what corrective actions can I take?
I was thinking I would dig down another 1' and fill it with gravel. Then put the biscuit on top of there. I'm just concerned that it will still result in water pooling above 42" though.
  • FYI, you only need to dig to 42". The bottom of the footing needs to be at your local frost-free depth.
    Jul 24, 2020 at 15:02
It is a little odd that only a few of your holes filled in with water, it may indicate something underground like a spring. More serious conditions would include hitting a sewer or irrigation line but it should be pretty easy to determine if this was the case.
Typical deck footer construction in freezing locations calls for full-depth concrete footings poured using sonotubes (cardboard form tubes) all the way to a few inches above the surface. Posts are anchored to that concrete but shouldn't be buried in it (building codes may vary).
This article explains frost heave and how to counter it. For large deck installations in especially frost-prone areas, they use concrete "bell" footings that are wide at the bottom, these help resist frost heave and upward movement. But as long as your footing is deeper than the frost line, it shouldn't be affected by the heave as it's nestled in deeper soil.
According to decks.com water in the hole is not a problem for mixing concrete. You may want to compact gravel around the concrete form tube before or after you finish it.
Finally, this article suggests putting large stones into the wet spots at the bottom so the mud flows into it and provides a good base for the concrete footing. You wouldn't want the stone layer tall enough that it puts your concrete footing above the 42" frost line though.
  • I thought it was odd too. It was the holes closest to the house that got wet. My sump pump runs every 15 minutes too, so I think either the water table is really high or there's a spring under the house.
    – Lefka
    Jul 24, 2020 at 17:00
This is not uncommon as in some places the water table is very close to the surface. I used to live at a place in Ohio where if you dug a 1' hole it would fill with about 10" of water.
The consideration here is not freezing since you are below the frost line but to ensure that any materials you put down the hole can stand up to continuous water exposure. That pretty much rules out any wood-based product as they will deteriorate due to water exposure.
I'd probably opt for a concrete post extending well above the current water line as it may rise and fall with rain or other weather.
  • I'm in Central IN - I used to tell my wife that you could just "jab a pipe into the ground and put a pump handle on it" if you needed water. Sounds about the same in OH... (I came from a land where a 1500' well was shallow - mountains will do that to you.)
    Jul 24, 2020 at 15:12
  • This is sounding more and more like what I'll have to do. I was opposed to a concrete pier simply because I haven't worked with cement yet. Sounds like I just need to do it though.
    – Lefka
    Jul 24, 2020 at 17:02
