I previously asked this question Is this mold or some other substance? where I discovered some mold behind a bathroom panel. The sensible thing to do would be to just throw the mold contaminated parts away and replace them. However I put the panel back in because I needed to hold onto the mold for certain reasons and I'm trying to come up with something better than putting it back into place or leaving it out which would be even more hazardous.
I'm thinking I could
- cover the effected parts with foil, tape then put back in to place.
- Alternatively I could cut the affected parts off and put it into a sealed plastic container. If so what can I use to do the cutting to make the least amount of mess? Im not sure what material it is.
Any idea on what might be the best way to approach this? I don't have a private balcony or anything where I could simply store the items in the mean time.
Thanks.
