There is a doorway that sometimes people walk through and get scratched on their arms by the latch on the door and occasionally it even draws blood. I think it's because the two external corners of the door latch are too sharp.
How can I make the door latch safer? Is it OK to use a Dremel rotary tool to round out or flatten the corners a bit?
    A picture of the latch would help us in offering solutions
    – Kris
    Jul 24, 2020 at 1:19
    I think you answered your own question.
    – JACK
    Jul 24, 2020 at 1:57
A Dremel may be able to work but it is also possible to way overdo the grinding that a high speed tool like this can do.
If all you want to do is to break sharp corners all you need is a low cost hand file. File with a cutting surface called a mill file will give you nice smooth cuts of the sharp edges.
Here is a typical mill cut file.
Picture Source
  • A 4” inch angle grinder would take off too much material too quckly but a dremel will be fine with a sanding paper.
    – Solar Mike
    Jul 24, 2020 at 4:11
  • You can just use the grinder wheel like a file and it'll work. They just need to make it "not sharp", which should be 3-4 strokes at most.
    – Nelson
    Jul 24, 2020 at 5:44
  • I agree a mill file is the proper tool for the job a bastard file would be two aggressive and would not leave as smooth of an edge.
    Jul 24, 2020 at 8:19
  • or even a sharpening stone. or the back of utility knife
    – Jasen
    Jul 24, 2020 at 11:35
