It wouldn't be electrically possible without a legion of relays.
The problem is, the switch was only ever intended to be used at the time of installation. You would have to open up every single -- how many of these are you installing? -- and throw the switch. Might as well just keep the ladder in the living room at that point.
You could come off the switches with 3-4 wires, and extend those out to another switch... but you would have to do that per light, so now instead of a ladder you only need a broomstick with an eyebolt screwed into the end.
Why not wire all the switches in parallel over to a light switch in the wall? Because the power supplies are not designed to all be shorted to each other like that.
So the only way that works is to have 1-2 relays at each light location, with the relay contacts wired to emulate the switches. Then, the relay coils could be paralleled and supplied from yet another independent power supply (though you might be able to tap your furnace's 24V 40VA transformer for this purpose).
Reputable firms make this. It's expensive, but it isn't a support dead-end like this would be.
The sheer amount of labor and troubleshooting involved makes it a highly improbable venture. Further, it would be totally unsupportable except by the mad genius who built it, so would be a very serious problem at resale. If you're that intense into home automation, go for it except use reputable parts.
But for anyone else, it seems like you'd be better off talking to the lighting shops that supply million dollar mansions ($10M mansions in NYC, SF, LA, Boston) and getting well-supported stuff from reputable vendors.
