I have a patch on my wall where the rolled paint goes completely flat against the wall so it looks like it was brushed on in that area rather than rolled like the whole wall.
Before I painted it there was a patch of paint there that was really smooth, almost gloss like, I have no idea what was used but it was obviously to cover up something. Anyway, before I painted the wall myself I sanded down the whole wall included that area. I then put an undercoat/primer from Dulux™ over the whole wall.
I noticed when doing the primer it bubbled up in one part of that area but only a small bit and it then dried and looked OK. So I thought, that's it sorted.
When I then rolled the new paint, it looked fine then when it dried, in that area, there was no roller stipple (is that what its called?) it just seemed like it sunk into the wall and laid flat. I left it a day then did a second coat, same thing. I then resorted to dabbing the area with the brush to recreate a similar affect as the roller, but again, it dried and laid flat again!
I think I will end up having to sand back that area and redo it unless anyone has any ideas? Also, I don't want to go through the process then find it does it again anyway. I could, of course just ignore it as it is not noticeable unless close up but it is annoying me as i spent ages trying to do it all right.
Before I forget, I even tried applying a thin layer of filler and then over painting that with the roller and STILL it lays flat!
Picture Added: I have circled the part I mean otherwise where the camera loses focus it also looks flattened, also I will get rid of the obvious bits once figured out why it keeps going flat.
