I am estimating an approach in which I'd make a rabbet on a soft concrete wall. The dimension of the rabbet are roughly ~2cm x 3cm x 400cm.
My initial idea is to find a router bit (wood router) for concrete and use that. Conceptually this sounds fairly simple, but have found close to none results when searching.
Is rabbeting concrete a plausible approach and if not what are the difficulties?
    problem: unlike wood, there are no tools that cut concrete, concrete saws use abrasive discs that wear away the concrete. to approach the task with a router like tool would wear out lots of diamonds and make huge amounts of dust.
    – Jasen
    Jul 20 '20 at 12:41
    This sounds more than a bit like an XY Problem. What is the purpose of the rabbet (i.e. what is the real problem you're trying to resolve), and what is a "soft concrete" wall? Is that concrete that's starting to crumble from age?
    Jul 20 '20 at 12:52
  • Also, there's a third dimension to your cut. 3cm? 30m? Please revise to describe the project better.
    Jul 20 '20 at 13:04
Use a masonry saw much like a chain saw but with a large disk instead of the bar.
Then make 2 cuts 1 horizontal and one vertical.
You will need to use a rail or guide to cut straight lines.
  • Is there something essentially different between a masonry saw and a woodworking circular saw with a diamond blade? Jul 20 '20 at 11:45
    The power comes to mind.
    – Solar Mike
    Jul 20 '20 at 11:48
  • this tool is know here as a "quick-cut saw" that may be a brand name. water is used as a lubricant which prolongs the blade life,
    – Jasen
    Jul 20 '20 at 12:34
  • Yes, a typical circular saw will have a tough time providing enough torque to keep the blade moving in poured concrete. Also, the concrete dust will destroy the bearings in short order.
    Jul 20 '20 at 14:18
Use the a wall chaser, this is a tool electricians and plumbers use to cut chases (small trenches) in concrete, but fit only one blade (use a washer in place of the other(s)) do one cut from the top and one from the side.
  • What tool would that be, and why would it have more than one blade? This answer is confusing and incomplete.
    Jul 20 '20 at 14:17
    It's a wall chaser, very common in Germany for example where pretty much all walls are full masonry. See my answer here: diy.stackexchange.com/a/185938/65622 It has 2 blades to make 2 parallel cuts at once in order to make a chase or slot in the wall. Jul 20 '20 at 14:38
    Sexy tool. I do not need one, but i want one. I could see that having it when you need it would be very useful.
    – Alaska Man
    Jul 20 '20 at 21:03
  • you can probably rent one
    – Jasen
    Jul 21 '20 at 6:05
  • It's like a hand-held dado stack for concrete. What's not to love!
    Jul 21 '20 at 13:16
