Any ideas for getting this guy on the left out? When I unscrew it I just hear a squeaking sound. Guessing that the nut has rusted onto the bolt and the whole plastic assembly is turning.
Thanks
Sign up to join this communityAny ideas for getting this guy on the left out? When I unscrew it I just hear a squeaking sound. Guessing that the nut has rusted onto the bolt and the whole plastic assembly is turning.
Thanks
Cut the head or the nut off with a small saw or drill.
I have even used a small hacksaw blade held in a bit of rag and gently cut through like that.
Using a saw, it's easy to scratch the toilet. What i've done in the past for a problem like this was taking a hot soldering iron to push it out through the plastic without unscrewing. Make sure the nut head can be removed w/o the plastic stopping it. This will break the plastic part, but that usually comes with a new seat.
