Porter Cable DA250C 15 gage finish nail nearly new just stopped firing? Just releases a bit of air.
    Tell us what you've done for troubleshooting. Have you gotten a jam that isn't clear? Is the driver unit stuck down? Have you lubed it enough? Jul 19 '20 at 23:29
  • I had a problem with a Porter Cable brad nailer, in that the nailing rod/pin would not retract. Took it apart, didn't see anything obvious, but the problem is still there. Someone suggested one or both of the sealing rings on the air piston need to be replaced, but I haven't done that yet.
    – SteveSh
    Jul 19 '20 at 23:51
    verify that the air pressure is correct, this can happen if the air is too low
    – Ack
    Jul 20 '20 at 0:35
