I have a question that I think is really simple for you experts (naturally I'm a novice) so hopefully someone can help me out. I want to add an additional light to an existing light already installed in my basement about 10 feet away. At the existing fixture location, there is a 2-wire cable and 3-wire cable as shown in the attachment, and wired the same way. How is the proper way to connect a new light to the existing fixture. Is it as simple as me installing new 14-2 wire cable from a new light, and attaching to the neutral, hot (red), and ground wire at the existing fixture? Any advise or confirmation is greatly appreciated. Thank you.
Which wires in the light box are connected to the existing light fixture? – ThreePhaseEel Jul 19 '20 at 16:59
Just like in the image, there are 2 wires on the existing light (Red and White). The red attaches to the 3 wire cable (red wire), and the white neutral goes to a pigtail with 3 neutral wires. It's literally exactly like the image. – nhbarch Jul 19 '20 at 19:34
Great job for a first post! Excellent diagram.
Yes, you can easily add another fixture in the manner you described, assuming it's a 15 amp circuit (which is likely), if a 20 amp circuit, you'd need 12/2. You got it right.
Congrats also to do-it-yourself-help.com for updating their diagrams for 2011 Code. – Harper - Reinstate Monica Jul 20 '20 at 2:22
