I am having trouble finding 4x4's for an outdoor project right now. I'd like to mount an outdoor television about 5.5 to 6 feet from the ground. I was planning to use two 4x4x10' pressure treated boards about 3.5 underground in cement. There is no wood available right now. My question is can I use a 4x4x8' board (I have 2 of these already) and attach a 2x4 extension on the bottom end deeper into the cement? Or could I possibly use the the 4x4x8 with 2.25 feet underground? The tv is about 95 pounds, so I worry about the strength of the supports for the tv.
    "There is no wood available now?" Uh, what? Are people in your area hoarding 10, 12 and 16 foot 4x4's for covid now? Try a real lumberyard/building supply? Or use metal - conduit comes 10 (and 20 from a real electrical supply) feet long, stock, galvanized. A chunk of 2" rigid would overkill the job nicely. 2" EMT might do fine. – Ecnerwal Jul 18 at 14:45
    I was thinking conduit also because pressure treated is junk but 100 lbs is nothing I would be more concerned with wind loading. Defiantly would not be using a spliced 4x at the ground level. – Ed Beal Jul 18 at 14:59
  • @Ecnerwal Depending upon where you are, there is a scarcity of PT wood. I was a Lowes yesterday and about 80% of the racks for PT wood were empty. Apparently lots of DIYers stuck at home during covid19 are installing decks, porches, etc. Link to an article follows: hbsdealer.com/pressure-treated-lumber-demand-spikes – George Anderson Jul 18 at 15:12
    Go to a real lumberyard. Many of my home derpos are way out of stock, (not as bad at Lowes, curiously), but my real dealers are fine. – Aloysius Defenestrate Jul 18 at 16:41
  • And that makes total sense, since random consumers (present company excepted, of course) are so brand-hypnotized that they couldn’t find a real lumberyard with a seeing-eye dog. – Harper - Reinstate Monica Jul 19 at 16:02
