The ground wire is attached to my clothes dryer, but I don’t know where to attach the other end as it fell when I pulled dryer out—I don’t know where it fell off?!
    Can you provide a few pictures of the back of the dryer and ground wire? – JACK Jul 12 at 23:31
    Can you provide photos of the situation? Where on this planet are you, anyway? – ThreePhaseEel Jul 12 at 23:39
With grounding (and life) it depends. In the US, if it's a gas dryer you can get a ground clamp to the gas pipe connection. Assuming your home is properly grounded to the outlets, you can purchase a ground adapter for an outlet. The idea here is to dispell static buildup and provide an emergency path for electricity to take that isn't through you.
| improve this answer | |
  • Hello, and welcome to Home Improvement. Thanks for the answer; keep 'em coming. And, you should probably take our tour so you'll know the details of contributing here. – Daniel Griscom Jul 15 at 10:42
    Using gas lines to ground an appliance violates the intent of NEC 250.52(B) and 250.104(B) as well as NEC 250.130(C) and 250.118 – ThreePhaseEel Jul 15 at 11:47
