I have an LG LW1217ERSM 12,000 BTU window A/C unit and was wondering if it is possible to connect a remote temperature sensor to the unit.
For example, the unit is set to 72 degrees but the temperature in another room is 80 degrees. With the remote temperature sensor placed in the 80 degree room, the unit would continue to cool until that room is also brought down to 72 degrees. Unfortunately this unit does not seem to have this feature so I was wondering if it is possible to modify the unit.
Thanks!
