I installed an irrigation system for my lawn with 1/2" PEX tubing. Most of it is buried, but at the start of the run I want to run it through some PVC to make it look cleaner where it is coming up from the ground, where my water timer is.
My issue is I want it to look really clean, so I want the top of the PVC run coming up from the ground to have a female garden hose thread on it, where I can then attach my water timer. I am trying to figure out how I can connect my PEX line that is running through the PVC to a fitting that attaches to the top of the PVC with a female garden hose end. Any ideas?
One way would be to run your pex cable up the PVC pipe and put a PEX/ female hose connector on the end of the pex. (see below)
Another alternative would be to connect the pex to your PVC pipe at the bottom with this type of connector
and then at the top of the PVC pipe connect a female hose fitting
Your PC pipe would actually be under pressure at this point. These fittings are available at home stores and plumbing supply stores.
  • Thank you for your answer. I was trying to avoid using the PVC as a line because I wanted to use a much bigger diameter and use it as more of a conduit for the PEX line
    – Chad
    Jul 11, 2020 at 1:34
  • @Chad then something like the first picture, your large PVC with a cap on it, drill a hole in the cap and fit your female hose end to pex into the cap.
    – JACK
    Jul 11, 2020 at 1:49
  • You could also get a hose and cut off the female end with a foot or two of hose. Fit the female end into the hole in the cap and then connect your pex to the hose.
    – JACK
    Jul 11, 2020 at 2:00
