I currently have a 20 amp double pole breaker supplying a multi-wire branch circuit for two 120v receptacles in a double gang box.
I'd like to remove the 120v receptacles and install a 240v receptacle.
Can I simply attach the two hots and the ground from the circuit? If so, what should I do with the neutral wire?
