We have two dimmer switches in a finished basement room. Switch 1 controls wall lights, and Switch 2 controls overhead lights.
We are hoping to replace them with smart switches that require a neutral.
It looks as if Switch 2 is wired using a switch loop. (The white wire connected to Switch 2 is wrapped in black electrical wire, to indicate that it is being used for that purpose.)
From what I understand, the switch loop is an obstacle to using a smart switch, because the neutral wire is being repurposed.
What I'm wondering is whether it's possible to rewire (ideally without having to run new wire) to take advantage of the fact that there is a true neutral that is accessible within the box from the cables that are connected to Switch 1.
