I'm trying to finish up a composite deck project. We had been using SplitStop screws when we needed them, but I only need about 30 more and don't want to buy another box of them because they're very expensive, and I don't need anywhere near a full box of 275. I found a box of 'cladding' screws that looked similar and tried them, but had problems with them not going in all the way; they left the head exposed quite a bit, a good 1/4".
The original Split Stop screws have a blank part of the shaft, and then at the top they have strange threads, almost like 'flanges' that are perpendicular to the shaft. Occasionally we had the same problem with these, with them not going in all the way. Never could figure out why, anyone know?
Before these cladding screws, I thought I tried something like these, which look the same as SplitStop and had the same problem with them not going in all the way, but I'm going to give them a shot again.
The cladding screws are slightly different in that their last section, near the head, has reverse-threaded threads. I guess this is why they stop going in?
