I have kitchen cabinet in the corner where it has a revolving holder inside, which can spin so that it will use the space deep inside as well. The door for it has 2 panels. There are 2 hinges connecting the 2 panels. One of the hinges seem to be broken, so I'm wondering what's the name for that connecting hinge, so that I could order the part.
Appreciate if anyone can give suggestion on the name I can use to search this part.
Here are the pictures for the cabinet and close-up look of the hinge. https://drive.google.com/file/d/1EN-cwCVBGaAooCIw2TEwiJcKZVID4B30/view?usp=sharing
https://drive.google.com/file/d/15L2h-nTdpOtDBQn6CT05-T7qqjcCfWTF/view?usp=sharing
"Lazy Susan hinge" or "corner cabinet hinge" should do.
  • That makes sense. I was having trouble picturing it until I saw your links - I have a lazy susan in a corner cabinet and simply have an angled cabinet & door (i.e., 45 degrees from the cabinets on each side). Commented Jul 6, 2020 at 20:49
  • Thanks isherwood & manassehkatz, "corner cabinet hinge homedepot" works. homedepot.com/p/… The style looks slightly different from what I have, but it is exactly that usage. Appreciate the quick help.
    – Henry
    Commented Jul 6, 2020 at 22:28
    FYI, found the exact hinge matching my current style after adding "invisibile" to the search keyword. homedepot.com/p/…
    – Henry
    Commented Jul 7, 2020 at 0:21
