I am trying to set-up a home theater in my ill-equipped living room. After spending the last three days watching YouTube videos on routing cables, I did learn a lot, but got into a state of analysis paralysis in which I can't make any decision besides keep looking at more videos. I hope by posting here I can get some good recommendation that push me towards action
I am planning on setting up a 5.1.4 Dolby Atmos configuration with 6 speakers near the front of the room room (2 surround, 1 center, 1 sub, 2 ceiling reflective atmos placed on top of the two surround) and 4 near the back (the other 2 Atmos actually in the ceiling and the 2 back surround). I live in the second floor of a 3-floor condo, so obviously there is no attic. And wall and ceiling are fully finished. I am debating between the two main options of where to put the AV receiver, but the actual issue is how to run the wires:
  1. Put the AV receiver, router and all other components in the back of the room, just under the projector.
PROS: short HDMI run (12 feet) and short Ethernet run
CONS: I need to bring 6 speaker cables to the front of the room.
Straight wire path through the ceiling from back to front of the room Unfortunately the straightest path, shown in the first picture, is perpendicular to the direction of the joists and to fish the wire in the ceiling I would have to drill through seven joists, opening seven holes below them, including a big one in the back wall. I would tend to exclude this solution because the patching would be very visible, due to the bad combination of my poor skills and the light texturing of the ceiling .
Other possible options are: using 6 thin speaker wires glued to the ceiling on a straight line (i.e., following the red line but on the surface) or using plastic raceways along the longer route of the irregular perimeter of the ceiling/wall junction.
A last possibility would be running the wires inside the ceiling until the other side of the room (blue line in the second photo), and then go to the front wall from there. The first part of the path is parallel to the joist direction and it is a necessary route to connect the 2 in-ceiling speakers. I would basically carry along the other 6 wires until they get on the other side of the room. Wire path through ceiling and dropped ceiling The interesting thing is that on this side, as shown in the second photo, there is a dropped ceiling throughout the whole length, from the front wall to the back wall. One the positive side, the path inside the dropped ceiling to the back wall should be free of joists. However I am not sure what is in there, if I am allowed to run cables through it (a little online research gave me the impression that I could, using CMP rated wires, but not sure if it is also advisable). Also, if I did that, I would need to fish wires from so far below them that, just to start, I would not be sure of what to do to create that initial 90 degree turn with the cables above the real ceiling.
  1. The second option is putting the AV receiver near the screen, in the position occupied in the first photo by the old TV (which, together with the red couch strategically placed in front of the screen, owes its unexpected survival to covid lol). This different setup, actually, won’t change much in terms of wiring issues. The negative is a longer run for HDMI and Ethernet (about 30 feet) and the positive is that only 4 speaker wires instead of 6 need to be brought to the opposite end of the room.
And the options are the same: either running thin speaker wires glued to the ceiling, using plastic raceways, or fishing inside the real ceiling and the dropped ceiling on the other side.
None of these options seems that great. What would you guys do?
Thank you very much for any suggestions you would be kind enough to give me.
  • "I live in the second floor of a 3-floor condo..." so obviously the condo management will have the last word. Do you own the space above your ceiling or below your flooring?? A mistake on your part could be expen$ive. Jul 5, 2020 at 20:17
  • It would indeed. Having decided to go with the wireway as Ecnerwal suggested, the only thing that worries me is the noise that the in-ceiling speakers might transmit to the apartment above, but I haven't really found much info on the subject.
    – MarcoD
    Jul 6, 2020 at 12:59
This problem is most easily addressed by surface mount wireway. Rather than run exposed cables, you attach a fairly innocuous plastic or metal rectangular cross section wireway/duct/conduit that carries the cables across the ceiling and/or wall in a less obtrusive way than putting them out in the open, but which does not require major surgery to the building to install them. While you evidently don't like the ones you have seen so far, there are many options at many quality and appearance levels, so there may be hope that you can find one you like. Or get all 1970's retro and attach some hollow fake beams to the ceiling.
Where more convenient, there are also similar products made to go on the floor, typically with small ramps on either side so they are less of a tripping hazard.
Adding some sizable crown molding all around would be another approach to create hidden surface wire space along the edges of the ceiling, if that suits your taste better.
  • Hi Ecnerwal, Thanks for your suggestions. I believe you pointed out the saner way to do this, which is the direction I will go. I will look for those wireway you recommend, and probably use 4-conductor wires to connect pairs of speakers and keeping it all more ordered
    – MarcoD
    Jul 6, 2020 at 12:55
