Barn A contains the main panel. Barn B has a subpanel fed from Barn A via (3) 2-0 aluminum conductors, 2 hot and 1 neutral, with a 60amp breaker in the main panel. There is no grounding conductor between the main panel and subpanel. The water line between barns is PVC. Barn B was built in 2000. There is no ground rod in Barn B.
My plans for Barn B include at least one new lighting branch circuit, and a 50 amp RV receptacle (NEMA 14-50r).
My question(s):
  1. How should the ground wires for the existing and future 120V branches be connected?
  2. How should the ground wire for the 50 amp RV receptacle be connected?
    Direct burial, unless the conduit ends underground. I can see where the 3 wires come up out of the ground at Barn B. Barn B is a wood-frame pole building, so no grounded rebar, piles, ect. – Greenfun2 Jul 3 at 2:58
    Well, that was poorly done, as even direct burial rated cable (if this is) is supposed to be protected where it comes out of the ground. I suspect you are going to have to add a grounding cable to sort this mess out. If the "electrician" involved is still around, you might want to sue them for malpractice. Depending on your actual loads, I guess you COULD consider the "transformer trick" where by using a transformer at each end of the cable, the supply at the far end becomes a new primary supply and you don't need a ground connection back to the source. – Ecnerwal Jul 3 at 3:00
    Some of the exposed wire can be blamed on erosion, but not all of it. I was hoping to be able to safely avoid running a wire; it's just over 400 feet between barns. Actual load probably wont exceed 30 amps. A 16 amp AC unit (actual running current, 20 amp circuit), a 1.5 amp camper fridge, a handful of CFL lights, and a 750 watt microwave. – Greenfun2 Jul 3 at 3:26
    @Greenfun2 -- are you OK with parts that you are going to have to do a bit of work to find? There is a way out of this without running wire per se, but it requires something (namely, a distribution transformer) that's rather outside what big-box stores carry.... – ThreePhaseEel Jul 3 at 3:44
    One more thing: is there a space outside Barn B that can be used for a fairly sizeable piece of electrical equipment? – ThreePhaseEel Jul 3 at 3:45
