I'm almost ready to grout.
What unsanded grout should I use? Is it ok to any if the ones in the picture? The tube will be easier for me.
Do I need to use a sealer after?
After tiling using the leveling spacers system few where stuck in between that I cant reach to pull (close to the tile surface but no edge to pull), is it ok to leave them when grouting or u should find a way to remove them.
Just a question wondering, why not using silicon caulk instead of the grout since its water proof.
What color should I use with tile (is white ok?)
