I have a 100 amp sub panel being fed a 6/3 cable. The main Panel has a two pole 60 amp breakers.
How many breakers can I have, or how many amps can I have? All the outlets/receptacles will be 120v. Can I use twins? What is my limit?
This is for a shed with power tools, fairly light use. I just want lights and 120 volt outlets attached to the Sub panel.
Thanks, -Greg
Edit please... I'm looking for direct answers, not what I should change. I have 6x spaces can I put 6x 20amp breakers? I had two electricians suggest I can't but wouldn't tell me why.
