I want to connect two parallel, overlapping wooden beams by putting two steel “braces” on each of the ends of the overlapping stretch, so four in total. These braces should look like the one I’ve drawn, with holes for one, two, or more screws on both sides.
The beams rest against a board, so there needs to be room for the heads of the screws, but whether there’s a few millimeters space (like drawn) or several centimeters doesn’t matter. (10 cm are about 4 inches.)
I can buy the beams to fit the braces, so the exact dimensions are not so important. It just can’t be flimsy.
None of the search terms I’ve tried (like “steel bracket,” “steel connector,” or “steel clamp”) has been successful.
Thank you!
steel brace
  • start here duckduckgo.com/?q=beam+join+plate&iax=images&ia=images .... and here duckduckgo.com/…
    – jsotola
    Jul 1, 2020 at 23:02
    It sounds like you might have a bit of an XY Problem maybe edit your post to include a drawing and explanation of what you're trying to accomplish - there may be a better way of doing it than hunting down an obscure, at best, type of fastener.
    Jul 1, 2020 at 23:43
  • There is no common name for a plate like this; it's just a metal plate. Jul 2, 2020 at 0:45
    Can you counter sink the head of the screws in the "boards" so that the metal plate doesn't need a clearance bend? Simple, flat, screw-on mending plates should be reasonably easy to find.
    Jul 2, 2020 at 13:11
  • @FreeMan Good idea! That would also hold the head in place and make it easier to fasten the screws. But with regard to the XY Problem: Yeah, I’ll probably just go with a different solution that doesn’t need any parts that I don’t know how to get. Jul 3, 2020 at 8:04
