There doesn't seem to be a way to unscrew the handles from this faucet. Anyone have any tips?
4Try turning the chrome sleeves below the handles. – JACK Jul 1 '20 at 13:26
Tough to tell exactly from the pic but it appears the only way to access the cartridge/washers inside would be to close both water supply lines, and carefully unscrew the flange (round top piece) that mounts to the valve body with a pair of pliers using caution not to scratch the chrome finish. Once that flange in removed the entire faucet handle and guts should screw out.
Hello, and welcome to Home Improvement. Thanks for the answer; keep 'em coming. And, you should probably take our tour so you'll know the details of contributing here. – Daniel Griscom Jul 3 '20 at 15:34
