I'm in the process of tiling now (porcelain tile). I noticed that the seam between the Densheild and the drywall is slightly not even.
Do I need to use the all purpose compound (used for dry wall) to try making them even.
Or shall I use the thinset mortar that I will use for tiling?
Or shall I leave it like this?
These seams will be covered by the tile at the end.
I'm going to use this thinset (Custom Building Products Natural Stone and Large Tile 50 lbs. White Premium Mortar)
