My kitchen currently does not have a kitchen hood, so I'm planning to install it. At the moment there is a ventilation duct, my idea is to connect the hood pipe to the ventilation pipe in the drop ceiling so I don't need ductwork on the exterior wall for the hood. Is this OK or there is the need for having two separate ducts?
    When the hood fan would be on it would blow down into the ventilation duct and into the living space. I don't think you can join these. Is the ventilation duct to expel air from the living space or to bring fresh air in? – Jim Stewart Jun 27 at 12:04
  • The ventilation duct is to expel air from the kitchen space, it goes to the roof (top floor flat), that's why I thought it's possible to share the same duct. – Antonio Andrés Jun 27 at 12:41
  • Does the existing vent duct have a fan and if so is it at the bottom or at the top? – Jim Stewart Jun 27 at 15:47
  • It has a fan at the bottom (currently not working). – Antonio Andrés Jun 27 at 16:08
  • You would have to check with building management and building inspection. I would bet that you cannot have both. – Jim Stewart Jun 27 at 17:46
